Block category: Widgets
от автора
в
This is a shortcode widget.
The Archive Widget:
The same Archive widget but as a dropdown:
The Category widget block has an additional option for showing category hierarchies:
The Latest Comments widget can display or hide the avatars, the date, and the comment excerpt:
  1. Привет! Это комментарий. Чтобы начать модерировать, редактировать и удалять комментарии, перейдите на экран «Комментарии» в консоли. Аватары авторов комментариев загружаются…
  2. I want to learn how to make chinese eggrolls
Here is an example of the Comments widget with all the options disabled. The number of comments has been reduced to two.
And here is the Latest Posts widget in the list view, with dates:
Grid view, now sorted from A -Z.
You can also change the number of columns used to display the latest posts. The block below only displays posts from the Block category:
Комментарии
Добавить комментарий
